kgshankar1980
Full Member level 3
Re: 1. Interfacing SIM300 GSM module with microcontroller PIC6f877a
@Dhananjayal,
Ok fine...
Now follow the steps to check whether your SIM 300 gsm module is working properly or not..
1. Insert the valid sim card for the sim300 module.
2. Connect the UART of GSM module to hyperterminal.
3. Set the hyperterminal baud rate - 115200,8,n,1
4. Now turn ON the gsm module and see what results are you getting in the hyperteminal.
5. If you are getting "Call Ready" in the hyperterminal then your module is working fine.
If not then there is an issue with the module. Confirm this first and let me know.
@Dhananjayal,
Ok fine...
