pic microcontroller begins programming
you need to used MPLAB driver switcher.because MPLAB 8 and MPLAB X are different versions and different plateforms.
any one knows how to do workable in mplab and give me some examples.
thanx.
how to set configuration bits in terms of oscilators?
if i am using crystal of 4/8/12 MHz. what i should mention
in configuration bit.
weather XT/HS.
if i am usign crystal and mention in configuration as LP then what will be affect on
on current and speed.
got the solution myself for configuration bits
i was trying as written in manual of x8 compiler that as follows
__config(xt)
after trying lot
i just put semicolon in front of this it works.
manual never give semicolon
is it right?
how to set config by using preprocessor in xc compiler
thanx....and look at the prev. que plz
there is am option for creating configuration bits in a menu. It will automatically generates the code for you. Sometime the ide may be say a wrong code. But it'll work fine
