KhaledOsmani
Full Member level 6
Well,,
Last night i had spent it all soldering this circuit
This is the second or third time i do solder
An open wire circuit for such system is very mutable
Here ive been told to do soldering from betinning but i handt fot
The guts to do it
When finished it worked at first attempt
The system is more livable than it was
It was dying and tend to freeZe and resets
Now it is very ok working all up
The sensors reading to light and moisture are accurate and changes
When input changes
The only problem left is reading from lm35dz
It gives values of temp from 124 to 230 as maximum
Here the temperature is of 23 degree C
I just need to correct temp reading
Also the voltage residue from adc channels is still a problem
Because when i increase only light also the temperature
Increases and light increases too
When i increase moisture by placing soil moisture sensor inside a cup of water other variables increases too
Ive made a delay between reading from channel to another
Should i increase that delay (of 1 mS)
Or ?
Here is the pre-final circuit
To note: i am connecting a 1k resistor with the lm35dz output
The guts to do it
When input changes
Or ?
