KerimF
Advanced Member level 5
- Joined
- May 17, 2011
- Messages
- 1,554
- Helped
- 376
- Reputation
- 760
- Reaction score
- 379
- Trophy points
- 1,373
- Location
- Aleppo city - Syria
- Activity points
- 13,095
I asked if the 400Hz is generated internally because if it is the case then the signal would start as sinusoidal generated for a convenient amplitude. Then it will be shifted as you have suggested. Both sine waves will then be amplified and limited at the desired amplitude.
Note: In general it is hard to give a good/acceptable solution when the input source and the output load are not known clearly, mainly their impedance (along the amplitude of the signal). To you both external sides are clear because you know what you have... for others one can think of many possibilities.
