John Xu
Member level 3
bsim3 pclm channel length modulation
I have a question on the chanel length modulation parameter, i.e., PCLM. Can anyone pls. tell me if this parameter is the lambda in the drain current equation to account for the channel length modulation effect?
I have this question is because I set pclm equal and not equal zero, I found not much drain current descrepancy for a current mirror, alough I see their obvious different Vds.
Thanks in advance
Thanks in advance
