j33pn
Member level 2
Fuses are sacrificable devices (there are resettable polymer fuses though) that are expected to commit suicide just to save some other parts, usually damage from a higher current or voltage. In that philosophy, any fuse is better than no fuse. If a PCB trace used as a fuse can save us from a bigger fire hazard, then it must be welcome (notwithstanding standards).
A trace used as a fuse is worse than no fuse, it's an ignition source for a fire. The flammability ratings of PCB laminates don't come from being fire resistant like asbestos. They're classified as self-extinguishing, meaning that when they burn (and they do, b/c they are flammable) they produce so much thick choking smoke that the smoke can (self) extinguish any open flames. If the board isn't fused and a carbon arc has formed, the board will just keep on burning until the damage has grown enough to disrupt the fault condition or the fire department shows up.
