mayank.bhaintwal
and what about ground plane for return path.
Kotsche:mid layers will definitely solve your problem(considering your copper thickness+tin plating thickness,Er etc).......
but you can try reducing the dielectric thicknes and increase the copper thickness to achieve the mentioned 90 ohm differential impedance(like 47mils from 62mils(1.6mm)) and achieve the same in 2 layers.....i have done the same but for a different impedance value....
unless it affetcs any mechanical or other parameters....
hi
i just want to know that waht is the use of gnd plane for differential signal as i know that in differential pair both the signals gives refrence to each other.please expalin.
