Relayer
Full Member level 5
- Joined
- Jul 28, 2016
- Messages
- 293
- Helped
- 101
- Reputation
- 202
- Reaction score
- 65
- Trophy points
- 28
- Location
- Hoppers Crossing, Australia
- Activity points
- 3,297
Hello eagle1109,
The only way you're going to find the short is to eliminate one component at a time. But
only the components connected to the +12V rail.
Any resistors associated with the 12V's can be essentially ignored. What you're really looking for,
is a semi-conductor component. i.e. Rectifier, diodes, transistors and/or MOSFET's. Capacitors
and resistors are extremely unlikely to ever go short circuit.
You need to remove each semi-conductor component entirely, until the short is no longer there.
You should also check for the short on 200 ohm scale or higher on your DMM.
As its already been stated, using the buzzer side of your multi-meter isn't accurate at all.
Regards,
Relayer
Regards,
Relayer
