PC Parallel Port Pulse Generator
mazellan79
Junior Member level 1
parallel port signal generator
I am looking for a design and software for a PC Parallel Port driven Pulse Generator. Does anyone know of a design on the web?
Mazellan79
parallel port pulse generator
I did not come across something like you said. But I don't think it will be too difficult to write one as long as your pulse generator requirement is not very high. I will stay with the DOS/Win98 type environment. Use the borland C with the timer to talk to the parallel port. It will be very easy to do. The only difficult part is the resolution will be very low and It will not be a high performance system.
Good luck.
paralel port pulse generator
I tried to design this in delphi and I noticed that you can get a pulse every 100ms with 1ms accurancy.Maybe you can do better in dos or using those hi-speed timer dll-s.
Alex
Try TvicPort libraries which provide a direct access to hardware.
Bye.
pulse generator pc
someone got a c***k for this interesting prog?!?
