T
treez
We need an AC Mains current monitor to monitor the AC current going into our 3.8kw, 230VAC battery charger.
I found the HMS 05-P:
…But it look like it gives a voltage out which is just an offset sine wave with a 2.5V DC offset. (The datasheet isn’t terribly clear about this).
So we would also need an ideal diode peak detector to go with it, giving us a DC voltage representing the peak. Do you know of a mains current monitor which just puts out a steady DC voltage which is representative of the mains current?
