[SOLVED] Output expressions from ADEL are not read correctly by ADEXL
melkord
Full Member level 3
I did setup the simulation on ADEL.
To perform corner simulation, I use ADE XL which I launch from ADEL.
But the expression I made in ADEL are not read correctly by ADEXL.
I need to change some quote marks and to delete space on the expression in order for ADEXL to show/plot the results.
But there are still some expression that does not show ot plot the result.
What causes this? Do they use different syntax?
What should I do for the rest of the output that still not showing the results?
Wave expression does not work in ADEXL.
Try the following:
VDC("/VOUT") for dc voltage
IDC("M1/D") dc current
value(dB20(VF("/VOUT")) 1000) Output in dB20 at (1000 Hz)
tran ("/VOUT") transient of VOUT.
I found out a work around for this problem.
you have to cut (ctrl+x) on the expression, left click on any area outside the field, and paste (ctrl+v) the expression back into the field.
