styxies
Junior Member level 1
Hi, I am trying to design a pseudo-differential transconductor, but the output current is not stabilizing for larger values of Vin(differential) which results to a warped Gm vs Vin(differential) plot.
What could be the problem?
From the upper plot is the Gm vs Vin plot, while the lower plot is the current out.
The common mode of the input used is at 1V, anyother common mode value used will lead to a more warped Gm vs Vin(differential) plot.
