cipi-cips
Member level 4
Re: Oscilloscope
ok this is what I have created:
If you can notice it is the same logic for NAND and AND only that you get notQ at the output
Now I need to build offset can you tell me why didnt you put diode in series with resistors on Qa and Qb of the counter ?
One more thing if you can see for multiplexing it is used this QaQb, QaQb(not),Qa(not)Qb(not) and Qa(not)Qb for each NAND gate, now if you can se on the original schema (first schema that I've posted here) not only that pin 2 from counter is miswired it also wrong logic for forth NAND gate I think that pin 2 from IC7420 must connect to pin 9 of counter ?!
