Oscillator gain
Atif Hussain Shah
Member level 1
Member level 1
I am design an oscillator circuit for broad band range i-e from 100MHz to 200MHz.
The resonance frequency of the resonator changes from 100MHz to 200MHz as the Er of the substrate changes. The loss of resonator is around 4dB and its phase is around 150 to 170MHz.
With that resonator, I want to connect an amplifier in reflective mode so that the oscillator circuit completes.
The phase of amplifier is equal and opposite to the phase of Resonator so the phase condition of Bark-Hausten criteria is met but the gain of amplifier is less than the loss of resonator in 150 to 200MHz range. So Second condition of oscillator is not met in range 150 to 200MHz. The ciruit and response of Amplifier is attached below. How can I increase the gain to 4 dB. In full range(100 to 200MHz) of Amplifier.
@big Boss please help
Bigboss another problem i saw is that in transient simulation, the amplitude drops down. Is this related to transient simulator setup?
the settings of transient simulator are
You have already a Load at Collector ?? It's impossible to get Oscillation signal from Coaxial Resonator side in this configuration. I think you're doing something wrong.
BigBoss i think 50ohm termination is fine at the output. I had designed a circuit at 100MHz 2 years ago, and it worked perfectly. in that case i was taking output from emitter. You can see termination at 50ohm.
As 20dB attenuator has been used so output power is around +11dBm.
Its ADS results are attached
I write down 3 references for oscillator design. read those texbooks and work on math. and practical examples. Otherwise you go blind and you confuse all. OK ? You have to know what you're doing.
"Discrete Oscillator Design: Linear, Nonlinear, Transient, and Noise Domains", Randall W. Rhea
"RF and Microwave Transistor Oscillator Design", Andrei Grebennikov. 2007 Wiles and Sons
"Design of Modern Microwave Oscillators for Wireless Applications: Theory and Optimization", Ulrich Rohde. 2005 Wiley Interscience
Big Boss I am reading the books and I am very thankful to you for providing them.
I have made some improvements by reading them.
The harmonics has been reduced and now the second harmonic is 30dBc below than the fundamental signal. Before it was only 5dBc below the fundamental.
Also I have done the Negative resistance analysis and observe the oscillating frequency where imaginary part crosses the zero line.
And oscillating frequency has also been observed using one port analysis by looking the magnitude and phase of S11.
I have attached the results.
But I have not been able to run Transient simulation. Can I share the workspace so that you may have a look.
