[SOLVED] Opto coupler for energy measurment ?
Oh... so you don't have CD4000.lib, I asked you about it earlier I thought your silence meant you have it.
About LM339, I thought its model was loaded with LTspice libraries.
I will find the models of these ICs and post them here.
The only reason to use an external analog multiplier is if you can't multiply the two digital values together in a microprocessor. The analog multiplier will have significantly poorer accuracy.
I am not familiar with multipliers, digital or analog.
Do you think a 0.3% accuracy is not good enough practically?
To be honest, I got this accuracy from simulation when I used comparators and gates (switching method). In my preliminary design, I avoided using transistors and/or diodes as it is the case with various logarithmic analog multipliers that should be implemented in integrated circuits to get adequate accuracy.
@ADGAN
The text below should be named as:
CD4000.lib
Please note that since this library is rather long, the CD4000.lib here is for 4001 and 4070 only.
I kept the file name as it is since it is written so in the schematic (asc) you received.
* CD40xxx Model libraray for LTSPICE from www.linear.com/software
.SUBCKT CD40_IN_1 in out VDD VGND vdd3={vdd2} speed3={speed2} tripdt3={tripdt2}
* 3ns input delay
*.param Cval = 0.55e-12*4/({vdd3}-0.5)*{speed3}
* 10ns delay @5V
.param Cval = 1.8e-12*5/{vdd3}*{speed3}
.param vt1=0.5
.param gain=(1/{vdd3})
*D1 0 in CD40DIO1
*D2 in VDD CD40DIO1
R1 in out10 10k
C1 out10 VGND {Cval}
R2 in VGND 1e8
*E1 out20 0 out10 VGND {gain}
B1 out20 0 V=LIMIT(0,V(out10,VGND)*{gain},1)
AE1 out20 0 0 0 0 0 out 0 BUF ref={vt1} vhigh=1 tripdt={tripdt3}
.ends
* Standard output driver
.SUBCKT CD40_OUT_1X in out VDD VGND vdd3={vdd2} speed3={speed2} tripdt3={tripdt2}
.param trise1=80e-9*5.0/{vdd3}*{speed3}
.param Rout=500*5.0/{vdd3}*{speed3}
AE1 in 0 0 0 0 0 out10 0 BUF tripdt={tripdt3} trise={trise1}
E1 out20 VGND out10 0 {vdd3}
Rout out20 out {Rout}
*D1 0 out DIO2
*D2 out VDD DIO2
.ends
* 2-input NOR gate
* tpd 125n
* tr 100n
.SUBCKT CD4001B A B Y VDD VGND vdd1={vdd} speed1={speed} tripdt1={tripdt}
.param td1=1e-9*(125-40-10)*5/{vdd1}*{speed1}
XIN1 A Ai VDD VGND CD40_IN_1 vdd2={vdd1} speed2={speed1} tripdt2={tripdt1}
XIN2 B Bi VDD VGND CD40_IN_1 vdd2={vdd1} speed2={speed1} tripdt2={tripdt1}
A1 Ai Bi 0 0 0 Yi 0 0 OR tripdt={tripdt1} td={td1}
XOUT Yi Y VDD VGND CD40_OUT_1X vdd2={vdd1} speed2={speed1} tripdt2={tripdt1}
.ends
* 2-input exclusive OR-gate
* tpd 140n
* tr 100n
.SUBCKT CD4070B A B Y VDD VGND vdd1={vdd} speed1={speed} tripdt1={tripdt}
.param td1=1e-9*(140-40-10)*5/{vdd1}*{speed1}
A1 Ai Bi 0 0 0 0 Yp 0 XOR tripdt={tripdt1} td={td1}
XOUT Yp Y VDD VGND CD40_OUT_1X vdd2={vdd1} speed2={speed1} tripdt2={tripdt1}
.ends
LM339.asy
Version 4
SymbolType CELL
LINE Normal -32 -32 32 0
LINE Normal -32 32 32 0
LINE Normal -32 -32 -32 32
LINE Normal -28 -16 -20 -16
LINE Normal -28 16 -20 16
LINE Normal -24 20 -24 12
LINE Normal 0 -32 0 -16
LINE Normal 0 32 0 16
LINE Normal 4 -20 12 -20
LINE Normal 8 -24 8 -16
LINE Normal 4 20 12 20
WINDOW 0 16 -32 Left 0
WINDOW 3 16 32 Left 0
SYMATTR Value LM339
SYMATTR Prefix X
SYMATTR SpiceModel LM339.sub
SYMATTR Value2 LM339
SYMATTR Description Quad Single Supply 3V/5V Comparator LM339
PIN -32 16 NONE 0
PINATTR PinName In+
PINATTR SpiceOrder 1
PIN -32 -16 NONE 0
PINATTR PinName In-
PINATTR SpiceOrder 2
PIN 0 -32 NONE 0
PINATTR PinName V+
PINATTR SpiceOrder 3
PIN 0 32 NONE 0
PINATTR PinName V-
PINATTR SpiceOrder 4
PIN 32 0 NONE 0
PINATTR PinName OUT
PINATTR SpiceOrder 5
LM339.sub
* LM339 VOLTAGE COMPARATOR "MACROMODEL" SUBCIRCUIT
* CREATED USING PARTS VERSION 4.03 ON 03/07/90 AT 14:17
* REV (N/A)
* CONNECTIONS: NON-INVERTING INPUT
* | INVERTING INPUT
* | | POSITIVE POWER SUPPLY
* | | | NEGATIVE POWER SUPPLY
* | | | | OPEN COLLECTOR OUTPUT
.SUBCKT LM339 1 2 3 4 5
F1 9 3 V1 1
IEE 3 7 DC 100.0E-6
VI1 21 1 DC .75
VI2 22 2 DC .75
Q1 9 21 7 QIN
Q2 8 22 7 QIN
Q3 9 8 4 QMO
Q4 8 8 4 QMI
.MODEL QIN PNP(IS=800.0E-18 BF=2.000E3)
.MODEL QMI NPN(IS=800.0E-18 BF=1002)
.MODEL QMO NPN(IS=800.0E-18 BF=1000 CJC=1E-15 TR=807.4E-9)
E1 10 4 9 4 1
V1 10 11 DC 0
Q5 5 11 4 QOC
.MODEL QOC NPN(IS=800.0E-18 BF=20.29E3 CJC=1E-15 TF=942.6E-12 TR=543.8E-9)
DP 4 3 DX
RP 3 4 46.3E3
.MODEL DX D(IS=800.0E-18)
.ENDS
* Model for packaged LM339 devices
* 14-pin DIP, 4 comparators per package
* CONNECTIONS: Output 2
* | Output 1
* | | Positive Power Supply
* | | | Input 1 Inverting
* | | | | Input 1 Non-Inverting
* | | | | | Input 2 Inverting
* | | | | | | Input 2 Non-Inverting
* | | | | | | | Input 3 Inverting
* | | | | | | | | Input 3 Non-inverting
* | | | | | | | | | Input 4 Inverting
* | | | | | | | | | | Input 4 Non-inverting
* | | | | | | | | | | | Negative Power Supply (or Gnd)
* | | | | | | | | | | | | Output 4
* | | | | | | | | | | | | | Output 3
.SUBCKT LM339_DIP14 1 2 3 4 5 6 7 8 9 10 11 12 13 14
X1 5 4 3 12 2 LM339
X2 7 6 3 12 1 LM339
X3 9 8 3 12 14 LM339
X4 11 10 3 12 13 LM339
.ENDS
Sorry for the late reply, was busy with project work & lectures. Thank you
I bet you are much busier than I. Please take your time. Me too, I may be busy anytime unexpectedly.
Since I solved the attachment issue (see thread), I attached the previous files (as zip) after making some cleaning.
  • DualSupply_05-quasi-.zip
Reactions: ADGAN
    ADGAN
