Yantob
Junior Member level 2
- Joined
- Oct 30, 2007
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Sunderland UK
- Activity points
- 1,440
I'am contemplating buying an easypic4 will i be dissapointed ?
blueroomelectronics said:The easypic4 is an experimenter board, the programmer circuit is very basic and similar to a JDM programmer.
Get a PICkit 2 instead as it's cheap and fully supported by Microchip & MPLAB. It's a real debugger too.
If you want to learn the 18F series basics can't go to wrong with my Junebug kit.
xorcise said:blueroomelectronics said:The easypic4 is an experimenter board, the programmer circuit is very basic and similar to a JDM programmer.
I like PICKit2, it was my first PIC board some years ago. The Junebug looks like fun too. But there is no comparison to the capability and functions of the EasyPIC4 board. I also find no similarity to JDM. The EasyPIC4 board has a USB PICFlash In-circuit Programmer/ICD and programs possibly the largest number of DIP PIC's compared to other commercial programmers.
We were able to use the EasyPIC3 and EasyPIC4 for our development with USB PIC's, changing programming on the fly as necessary without removing the PIC and remaining connected simultaneously with the PC.
By the way, you might want a longer cable on your car-bot...
Yantob said:er looks like paltronix will soon be getting some of my cash for the easypic4 almost there anymore diswaders or perswaders ,Thankyou for all your replies this really is the best forum ive come accross
blueroomelectronics said:The EasyPIC4 programmer uses both proprietary software and hardware neither of which are MPLAB compatible. The PICkit 2 supports programming hundreds of PICs from the 10Fxxx thru dsPIC33F and debugs most 16F & 18F PICs from within MPLAB.
Any proprietary programmer will always be behind in updates compared to a Microchip supported device or clone.
Yantob said:the problem i find is programming my main expertise is electronics i needs a microcontroller in most designs to reduce size and cost if i could i would farm out the programming bit but like most prototype work i need to do many changes ..so as you can guess i need as lots of help and i fine basic just the better option .
ful babu said:well no offense, MPLAB is a really clumsy tool as well as its c compiler comparing to ccs, iar and mikroe compilers, even I wud prefer ht c compiler over microchip’s one. Any way I hav easypic4 , and mikroec compiler they are easy to use and u can work fast, this tool suit is really smooth
regards
