windknows
Junior Member level 2
did you try setting Vdc to half the supply instand of zero?
the feedback will force the output to follow the input, so if you set the input to zero, the output will also be closed to zero volt, and since this cascode only have limited output swing, the nmos in the cascode won't work anymore..
