T
treez
Is it ok that the LT6220 opamp has voltage on its input pins that is above its supply voltage?, as in the attached schematic.
Its just that the datasheet says on the front page that this is ok, but then in the “absolute max” section it says the maximum input voltage is +/-Vs.
These are contradictory statements.
If it is ok, then how high above the supply voltage are the inputs allowed to go?
LT6220 opamp datasheet:
http://cds.linear.com/docs/en/datasheet/622012fc.pdf
