SACHIN C
Full Member level 2
- Joined
- Jul 6, 2013
- Messages
- 143
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 18
- Activity points
- 1,048
Kam1787,
Trancation means limiting digits or signal value up to certain level & then above which it will not pass but,in our case while observing signal on CRO Op-Amp Signal displays lifted by 3.58V with respect to ground(which is center tapped point of the transformer).
So shall i need to change resistor ground at input of Op-Amp,as shown in above attached file?
XR2206 Supply Connection is +15V & ground so it is the stage where the signal is lifted?
Thanks,:smile:
Thanks,:smile:
