cupoftea
Advanced Member level 6
- Joined
- Jun 13, 2021
- Messages
- 3,072
- Helped
- 62
- Reputation
- 124
- Reaction score
- 139
- Trophy points
- 63
- Activity points
- 16,044
For equipment powered by the mains, the signal circuitry generally runs off secondaries isolated from the
mains. However, during use, it often gets connected to other signal circuitry which, most often, has earth
ground as its ground. So therefore, when they are connected, you really want both of the signal
circuits to have grounds which are at the same potential
(ie, to both be at roughly earth potential).
..So is it best, where possible, for an offline SMPS that is supplying signal circuitry, to have say a >1MEG resistor
across its isolation barrier and connected to earth on the mains side?
(so that the secondary doesnt float off away from earth potential.)
Generally would you agree, that totally floating secondaries are not good, because they can float up (due to charge pumping in the stray C) to
overly high potentials?
