Offline 230VAC Flyback SMPS with TO220 FET and legs not bent..Too close to each other
Certainly sharp edges don't help - like the steps on the leads on the TO-247 ...
Reactions: treez
    T
Thanks, though i am speaking of a TO220 FET soldered into a PCB with straight legs. The actual soldered pads , as you know, do not have solder resist over them...There is solder resist between the PTH pads on the PCB, but i dont think that makes it category B4...to get category B4, we would have to spray a insulative coating over the pads, and we have not done this, but as Betwixt says, the D and S are close together n and inside the TO220 body anyway.
Read the specification you put a link up to properly, ie do your homework before coming back with an incorrect supposition, read section 6-3-4 it explains it all, now we have used this spec for military and aerospace and have had everything passed in the past.
And this site will give you advise for equipment that may get dirty etc. Ie 60950 distances to cater for pollution levels.
http://www.creepage.com/
