Non isolated AC voltage sense
satiz
Member level 5
Hi There,
I am planning to using Differential amplifier for AC voltage sense . I want formula to find V2 in the attached circuit.
My aim is to find the differential amplifier output. To get that I want to calculate Differential mode voltage
Vd= [Non-inverting input] - [Inverting input]
I need formula to find Inverting terminal volt and non inverting terminal volt.
Please help me.
Thanks regards
Satiz
Why do you say "differential"?
I see a "voltage divider* and a "non inverting Opamp circuit".
Hi Klaus,
Simplified circuit is attached for your reference.
Two things represent the typical difference amplifier circuit:
* it contains 2 x 2 equal resistors
* and the most important: no input does reference to GND
Signals (or circuits) that reference to GND are single ended signals.
They are no difference signals, no relative signals, they are absolute signals.
Tell us your idea, why do you call it "difference amplifier".
I agree with your point.
This is a TI reference design. they have mentioned as Differential amp and formula also matched with there given gain.
Here is the link for that. Please refer Non Isolated voltage sense section. (2.2.2)
https://www.ti.com/lit/ug/tiduby7a/tiduby7a.pdf
Below is easy reference
Please refer this circuit too
https://www.ti.com/lit/an/sboa092b/sboa092b.pdf
PDF page number 24.
Easy reference image
Now that things clear up.
You showed only one part out of two.
Each single part is single ended. Only two wired together make it to a differential input.
The amplifier is configured in differential mode and depending on the application and the input voltage range, the gain can
be configured.
But here I don't agree with the author. Not the amplifier is configured in differential mode (the both amplifiers work independently)
..but the ADC is configured in differential mode...the ADC has two inputs, an inverting input and a non inverting input....here is the "difference".
you would normally have (2) large resistor strings, one going from + input to phase and the other - input to Neutral. then the low value feedback R and R to local 0v - this would be a true diff amp on the mains ...
I agree that differential voltage divider is the appropriate solution for most AC voltage measurement applications. There are cases where the measurement circuit ground is tied to one input voltage terminal. Then a single ended voltage divider as used in post #1 does the trick. The amplifier adds an offset voltage to achieve a bipolar range but doesn't involve a substract operation because input and output ground are identical. Respectively there's no CMRR figure.
The circuit in post #5 is referring to a difference amplifier, as probably noticed, the resistor ratio is adjusted for the 3.3k voltage divider output resistance. If I understand right, you don't know how to calculate the circuit gain. But that's rather trivial, two cascaded dividers and a non-inverting amplifier. I think it's more straightforward than referring to a modified difference amplifier calculation.
Reactions: satiz
    satiz
I calculated the gain using differential amplifier formula, Check the Image 1. CMRR is 114db. If this is Ideal opamp both the input terminals are virtually shorted. But I have doubt here to calculate non inverting terminal input voltage.
With not connected HV input nodes:
GND - 3k3 - 8k2 -V- 14k2 - 2V5
GND - 11k5 -V- 14k2 - 2V5
-V- is the node for non inverting OPAMP input.
use the voltage divider formula
Can anyone tell me, how can I add LTSPCIE .asc file here
rename it as .txt and upload it as attachment.
CMRR is 114db.
Maybe in simulation with almost ideal devices, but not in reality.
Here is the LT Spice file for reference
  • Non-Inverting Opamp Voltage sense_2.txt
