hagster
Member level 4
Generally speaking(there are exceptions. E.g colinear). High gain antennas are like a torches. They emmit most of their power forward. Thats great if if know the direction that you want to transmit or receive from.
Low gain antennas are more like lightbulbs. They 'shine' equally in all directions. Great if you dont know where to point. Your cell phone has a low gain antenna because you dont want to have to point it at a tower to work. This is the same for tx and rx.
Remember that there is 'reciprocity' for antennas. This means that an antenna has the same transmit gain as recieve gain.
The choice of high or low gain is completely application specific. You may want a low gain tx antenna and a high gain rx. E.g. for broadcast TV where the transmitter to houses in all directions, but the houses can point a yagi at the transmitter. But for day GPS the satellite needs a high gain antenna to direct power towards thr earth, but the receiver needs a low gain antenna to pick up signals form satellites in lots of directions.
As always in engineering the answer to a very general question is "it depends"
