.lef (Layout Exchange Format) --> physical library
.lib (liberty format) --> logical/timing library (both slow and fast library)
.io (Input/output) --> I/O pad libraries
.sdc (Synopsys Design Constraints) --> constraint file which is obtained from synthesis output
.v or .vhd (Verlog or VHDL code) --> RTL code of the design
