macobt
Member level 1
Hellokaresz said:Hi macobt_delay isnt a problem,
Stop Yungs!
I told, that PICs pinout(Vdd + Vss) are wrong, not the full circuit_ & these is right/true....
Second: The Input range is dangerously soluted, its indiscutable; but with proper dimensioning it can be OK.
If you wish it only for 30V range=is simple to make , you can see it, corrected, on my schema....
3,
OK, the LEDs are yet clear; Trimmer has maybe 5 &10mm distances_I can make the PCB_or are you other meaning pls?
regards!
K.
If I make it,I will measure below 30 volts it is for my adjustable power supply from 1.25 to 15 volts.
The trimmer(you choise,is not problem which size,just to be 50K)
