need help.. uplink power control LTE using MATLAB
epy
Newbie level 2
Newbie level 2
jakarta
helo there..
i need help in simulating algorithm uplink power control LTE using matlab..
there are several references from IEEE journals mentioned system level simulator and link level simulator.. what are the differences between them?
and what are the major aspects simulating uplink power control.??
and last, is anyone has block diagram or flowchart for uplink power control or system level and link level simulator?
thanks
I am also working on same topic.. till now what u did in that ..??
well, i've been searching for lte toolbox. now i'm still learning its code and find a way to modified or insert the PUSCH algorithm.
how about you?
Basically, i am trying to find out the relation between PAPR reduction and Power Control in mobile communications... for getting MATLAB codes, is there any good website related to that..???
Need help......
Currently i am trying to simulate the uplink power control lte using matlab. Can u please provide me the details about the simulator.
Hi epy,
Have u found the solution to simulate the uplink power control using matlab. Currently i am doing project in this module with vienna LTE uplink simulator and trying to change the Power of PUSCH channel. Can u please suggest me a good ideas, how to implement power control in matlab.
many thanks,
sathish
