[General] Need help in MplabX and pic24f
i build also this project but when i m modify the configuraion of pin of LCD he doesnt work in isis i m modify
// LCD display ports etc
#define LCDdata LATE					// data port
#define LCDdataEnable	TRISE
#define RS LATBbits.LATB15				// RS bit in LCDstatus
#define RW LATDbits.LATD5				// read/write bit in LCDstatus
#define E  LATDbits.LATD4   			// enable bit in LCDstatus
#define Eenable TRISDbits.TRISD4
#define ERSenable TRISDbits.TRISD5
#define RWenable TRISBbits.TRISB15
with
//#define RS LATBbits.LATB15				// RS bit in LCDstatus
//#define E  LATDbits.LATD4   			// enable bit in LCDstatus
//#define Eenable TRISDbits.TRISD4
//#define ERSenable TRISDbits.TRISD5
#define RS LATDbits.LATD0
#define E LATDbits.LATD1
#define LCD_D4 LATDbits.LATD2
#define LCD_D5 LATDbits.LATD3
#define LCD_D6 LATDbits.LATD4
#define LCD_D7 LATDbits.LATD5
#define ERSenable TRISDbits.TRISD0
#define Eenable TRISDbits.TRISD1
#define LCD_D4_Direction TRISDbits.TRISD2
#define LCD_D5_Direction TRISDbits.TRISD3
#define LCD_D6_Direction TRISDbits.TRISD4
#define LCD_D7_Direction TRISDbits.TRISD5
I dont know why in your configurtion you aven't define al the pin?
which pin? I don't have an explorer 16 with a working LCD at the moment but I seem to remember the code working
I certainly have code operating on a LCD on a Bytronic PIC24 mechatronics trianer
this is the working code (pins could be different to the explorer 16)
// lcd.c -  functions for the PC1602-J lcd display 4-bit mode
// see http://www.repairfaq.org/filipg/LINK/F_LCD_progr.html
#include "hardware.h"
#include "lcd.h"
#include <libpic30.h>	// for __delay_us FCY must be defined!
#define LCDstatus LATEbits    	// control/status port
#define RS LATE4				// RS bit in LCDstatus
#define RW LATE5				// read/write bit in LCDstatus
#define E  LATE6   				// enable bit in LCDstatus
//void lcd_delay() { __delay_us(800); }//mSecDelay(1); }  // if LCD does not work make this longer
// Write a nibble to the LCD
// may have to adjust delays to suit the processor and clock
void lcdNibble(int n)
    int lcd=LCDdata;
//	lcd_delay();
	__delay_us(800);
  	LCDdata = (lcd&0xfff0) | ((n & 0x0f));			// send out lower Nibble
	//lcd_delay();
// 	__delay_us(1);
  	Nop();					// Wait E Pulse width time (min 230ns)
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
  LCDstatus.E=1;					// take clock E high
// 	__delay_us(1);
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	//lcd_delay();
    LCDstatus.E=0;
 	__delay_us(800);
	//lcd_delay();
// Write a Control Command to the LCD
// This is written as two nibbles
void lcdCmd(int c)
 	LCDstatus.RS=0;			        // Take RS pin low for command
	lcdNibble(c >>4);		        // Makeup Upper Nibble
	lcdNibble(c);			        // Makeup Lower Nibble
// write a data byte to LCD
int lcdPutchar(int d)
//    printf("%c", d);
	LCDstatus.RS=1; 				// Take RS pin high for data
	lcdNibble(d >>4);     		    // Makeup Upper Nibble
	lcdNibble(d);		            // Makeup Lower Nibble
    return 1;
// Initialise the LCD in 4bit Mode
void lcdInit()
   // TRISEbits.TRISE4=0;  	// set RS and E bits output
    //TRISDbits.TRISD1=0;  	// set RS and E bits output
    TRISE &= 0x0;          // set bits 0-3 output for data
    TRISE |= 0x80;
 	LCDstatus.RW=0;			// Take RS pin low for WRITE
	lcdNibble(0x3);		// This put the LCD into Soft Reset
	lcdNibble(0x3);
	lcdNibble(0x3);
	lcdNibble(0x2);
	lcdCmd(0x28);			// 2 line, 4 bit mode
    lcdCmd(0x6);			// increment cursor after each write
    lcdCmd(0x1);			// clear display
    lcdCmd(0x2);			// home
    lcdCmd(0xF);			// turn disply on
// move to line (1 or 2) at position >= 1
void lcdCursor(unsigned char line,unsigned char position)
#define lcd_line_1 0x00 // LCD RAM address for the 1st line
#define lcd_line_2 0x40 // LCD RAM address for the 2nd line
#define lcd_line_3 0x14 // LCD RAM address for the 3rd line
#define lcd_line_4 0x54 // LCD RAM address for the 4th line
   char lineAddress[]={0x00, 0x40, 0x14, 0x54 };
   lcdCmd ((0x80 | lineAddress[line-1]) + position -1 );
 /*  switch (line)
	  case 1:lcdCmd (0x80 + position -1 );lcdCmd (0x80 + position -1 ); break;
	  case 2:lcdCmd (0xc0 + position -1 ); lcdCmd (0xc0 + position -1 ); break;
	  default : break;
//  lcd_delay();
void lcdString(unsigned char line, unsigned char position, char *string)
	lcdCursor(line,position);
	while (*string)
	  lcdPutchar(*string++);
// display string on line starting at position 1, clear rest of line
void lcdStringOnLine(unsigned char line, char *string)
	lcdCursor(line,1);
	int i=0;
	for(i=0; (i<20) && (*string); i++, string++)
	  lcdPutchar(*string);
    while(i++<20)
	  lcdPutchar(' ');
void lcdStringAtCursor(char *string)
    //printf("lcdStringAtCursor %s\n", string);
	while (*string)
void lcdClear(void)
	lcdCmd(0x01);
void lcdHome(void)
	lcdCmd(0x02);
// clear line 1 or line 2
void lcdClearLine(unsigned char line)
	unsigned char i;
	lcdCursor(line,1);
	for (i=0; i<20; i++) lcdPutchar(' ');
	lcdCursor(line,1);
void LCDtest(void)
	//mSecElapsed(const int counter, const int reset, const long unsigned int delay);
	mSecElapsed(2,3,0);
	int count=0;
	while(!mSecElapsed(2, 0, 10000))
		{ lcdString(2,1, "Mechatronics trainer"); ; count++; }
	printf("LCD count X %d\n", count);
FCY is defined in hradware.h as
#define SYSCLK  32000000UL		// 8MHz clock with FNOSC_PRIPLL (baud rate max is 115200)
#define FCY  (SYSCLK/2)		// 8MHz clock with FNOSC_PRIPLL (baud rate max is 115200)
Reactions: ings
    ings
ah ok, i think that code work with your board card not with explorer 16 .
