- Joined
- Jul 4, 2009
- Messages
- 16,522
- Helped
- 5,157
- Reputation
- 10,347
- Reaction score
- 5,211
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 139,705
Make sure you choose a P-channel MOSFET. LEDs draw a steady current from power up onward, incandecent (filament) lamps draw a surge until the filament has heated up and increased in resistance so you need to plan for more than calculated current. MOSFETS can usually handle short term overloads so it may not be a problem but it's better to plan defensively than regret it later.
Another point, the NE555 may 'misfire' and produce unexpected flashes because it's supply voltage is likely to dip when the lights come on. The dip is natural voltage drop in the wiring as more current is drawn but it can upset the internal operation of the timer. I suggest adding another 10uF capacitor directly across the GND and V+ pins of the IC, wired as close to the pins as possible.
Brian.
Brian.
