NCP1203 equivalent ic
Gaber Mohamed Boraey
Full Member level 3
Hello everyone
That’s a pwm controller ic in a smps board, used for fire alarm panel
Attached photos
The mosfet and the pwm ic is burned “ shorter” , and the ic not available in Local market, NCP1203 , is there any equivalent ic for this?, or I can use power module instead of mosfet and ic?
Here the power module I mean
Mainly it’s for TVs power supply, so how you think to use here?,
I would prefer equivalency ic, how you think?
Regards
It's a common SMPS controller function (current mode flyback) but with special features (built-in oscillator without external RC circuit). Unlikely to find a drop-in replacement. Industry standard controllers like UC3842 can be probably used with additional components and swapped pinout, not well suited for repair.
Also there's a certain risk that more components than only controller and switcher FET are damaged.
LaTeX Commands Quick-Menu:
