kabiru
Banned
How sinewave is generated in PWM inverter?
Thank's for the reply, now are you saying if i generate high freq out put (square wave) let say 15-20khz with my pwm ic like SG3525 or TL494 then using low pass filter will eliminate high freq and alow the low freq to pass ? are you taking about space vector?
Added after 12 minutes:
i am using IR2110 hi&lo side driver as H-bridge arrangment and how can i generate sinewave info?
