[SOLVED] my pic18F4520 is not responding for any thing
srjth.m1
Full Member level 3
Full Member level 3
India
my pic18F4520 is not responding for any thing when am touching in RA6 pin some pin`s of some ports will get activated(tested with LED)
-4mhz XT oscillator..pls reply fast somebody....
You do not really tell us anything about your set up.
You need to show your circuit and program code.
Are you using a breadboard ?
Why are you using a 4mhz Xt oscillator whn you have an internal 4 mhz one ?
i just want to activate the port and just to blink the LED ,How to activate internal oscillator iam using Micro C pro v-5.6.1
i mean XT-4mhz is an internal oscillator am nt using any external oscillator,am doing in breadboard only
You should first show us the schematic of your arrangement and the code. You should also ensure that all connections are proper (no loose connections).
itz just an example i have changed the mcu and coding.......
Your circuit looks good, apart from the Mclr line.
What does your Config line say for MCRL = ON or OFF ?
If it is ON then it needs to be MCLR pulled up with 10k, or if you programmer is still connected you can, depending on programmer type, release it from program mode back to +5v high.
Also post you code incase you have a problem there - its easy to get things wrong when you first try to get going.
MCLR is ON and i hav connected it to a 5v through 10k....,and i have now tried with many programs..
mclr-on
oscillatr=XT 4Mhz
all others disabled..
this program is simply blinks the led connected to RB7
Code C - [expand]
8
9
10
11
12
13
void main()
 TRISB=0;
 while(1)
    PORTB.RB7=1;
    delay_ms(500);
     PORTB.RB7=0;
     delay_ms(500);
itz also not working........!8-O...my ports not activating when am touching the RA6 pin some ports getting activated!!
Thanks all,.....!my problem was in config i have changed oscillator to internal and RA6,RA7 to port function
Good that you have got it running, think you ought to set the other Config parameters to ensure it works ok.
Here is what I use. ( assemly code show)
CONFIG OSC=INTIO67, PWRT=ON, BOREN=OFF, WDT=OFF, MCLRE=ON, LPT1OSC=OFF, PBADEN=OFF
CONFIG LVP=OFF, XINST=OFF, DEBUG=OFF, WDTPS=32768
The config tells the chip that you want to use its Internal oscillator, but you also need to use the OSCCON instruction to set the speed you want otherwise it defaults to 1Mhz.
Thank u verymuch wp100... how can i set OSCCON for internal oscillator??
Check this file. It is using Int OSC 4 MHz.
-------------Update-----------------
I think you can use OSCCON = 0b01101111;
  • led_blink.rar
Now i want to take input from port A when i am giving a high input the corresponding out put LED should glow so i have written the following pgrm but itz not getting
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
void main()
   TRISA=1;
   TRIS B=0;
while(1)
 if(PORTA.RA1==1)// if RA1 is  high then RB7 should glow
 PORTB.RB7=1;
else
PORTB.RB7=0;
Try this code.
void main() {
       TRISA = 0x02;
       TRISB = 0x00;
       PORTB = 0x00;
       ADCON1 = 0b00001111;
       CMCON = 0x07;
       while(1) {
               if(PORTA.F1 == 1) {
                      Delay_ms(30);
                      if(PORTA.F1 == 1) {
                           PORTB.F7 = 1;
                      else {
                           PORTB.F7 = 0;
You have set TRISA = 1; It should be 0x02; You are using RA1 so it is 00000010 which is 0x02.
  • led_switch.rar
  • led_switch.rar
THANK U internetuser2k12 ...I have to check it....!
i have done the connections,and the LED is blinking becz of the delay what should do?
That happens if you do not do debounce. If you press and hold the button the led turns on, if you release the button the led turns off.
actually i want to connect 6 led similarly now what happens is when am giving a high to A port it gives output forRB7 only
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
void main() {
       TRISA = 0x02;
       TRISB = 0x00;
       PORTB = 0x00;
       CMCON = 0x07;
       OSCCON=0B01101111;
       while(1) {
               if(PORTA.F1 == 1) {
                      Delay_ms(10);
                      if(PORTA.F1 == 1) {
                           PORTB.F7 = 1;
              else  if(PORTA.F2==1){
               Delay_ms(10);
               if(PORTA.F2==1){
               PORTB.F6=1;
               else
                PORTB=0;
Similarly..6 led's..when each switch ON corresponding led should glow..!
Here is the code
void main() {
       TRISA = 0b01111111;
       TRISB = 0b00000000;
       PORTB = 0b00000000;
       CMCON = 0b00000111;
       while(1) {
               if(PORTA.F0 == 1) {
                      Delay_ms(30);
                      if(PORTA.F0 == 1) {
                           PORTB.F0 = 1;
               if(PORTA.F1 == 1) {
                      Delay_ms(30);
                      if(PORTA.F1 == 1) {
                           PORTB.F1 = 1;
               if(PORTA.F2 == 1) {
                      Delay_ms(30);
                      if(PORTA.F2 == 1) {
                           PORTB.F2 = 1;
               if(PORTA.F3 == 1) {
                      Delay_ms(30);
                      if(PORTA.F3 == 1) {
                           PORTB.F3 = 1;
               if(PORTA.F4 == 1) {
                      Delay_ms(30);
                      if(PORTA.F4 == 1) {
                           PORTB.F4 = 1;
               if(PORTA.F5 == 1) {
                      Delay_ms(30);
                      if(PORTA.F5 == 1) {
                           PORTB.F5 = 1;
               if(PORTA.F6 == 1) {
                      Delay_ms(30);
                      if(PORTA.F6 == 1) {
                           PORTB.F0 = 0;
                           PORTB.F1 = 0;
                           PORTB.F2 = 0;
                           PORTB.F3 = 0;
                           PORTB.F4 = 0;
                           PORTB.F5 = 0;
  • 6_led.rar
