Nicholas
Member level 4
tny266 trouble
I made a multiple outputs SMPS using TNY266G, with 10VDC and 24VDC output. I found that when no current drawed from 10VDC output, the other output is around 25VDC. But when it draws 300mA from the 10VDC output, the voltage on the other output will turn to be up to 40VDC!! By the way, there is always no load on the other output when I got this result, what's wrong? Is it normal?
