venkates2218
Full Member level 6
This is the circuit used to switch the analog value from pressure sensor's output to microcontroller.Output from the pressure will be 0.10mV to 5VDC.
These output are connected to Y0 to Y7 pins.Channels are selected by using S0,S1,S2 and EN pins.If any output is not required means,EN pin is enabled and output from the multiplexer is disabled.
Problem is even if the multiplexer is disabled by enabling the EN pin,some of the output voltage are measured in both microcontroller and multimeter(For checking purpose).The volatge will be 0.25mV to 1VDC.
How to eliminate this error voltage..?
