[Moved]: for 6 bit ADC how to set the DAC parameter
madhusmita99
Newbie
Actually I am working on VCO based ADC in 180nm technology . I have some doubts related to that topic.
1.I am not getting the correct output after DAC when ramp and sine inputs are applied. so kindly let me know how u got the correct output
2. I have set the DAC (Vref=1,Vrise=0 ,Vfall=0,Vdelay=0,Vtran=.9)
3. I have set the clk frequency of 16.11 MHz .(vpulse period is 62ns and pulse width is 60ns) i.e reset signal to the counter
4. I have used ramp signal of duration 3.4u
(when time=0s, v1=1v
when time=3.4us, v1=400mv.). ADC count maximum when control volatge is .4vand minimum when voltage is 1v.
Kindly suggest the time duration of ramp so that i will get correct result.
Need help related to the output after DAC
Can u send me the sample output of DAC when ramp and sine inputs are given to the ADC.
Whatever I have attached the output file , that one is correct or not . Kindly reply
Re: Need help related to the output after DAC
It's not clear what you need.
Please post a complete specification. With vaues and units.
Klaus
How to set the ramp input parameter of ADC . so that it will give correct output.(I am getting the output as attached above )
I fear, most Edaboard users don't know much about VCO based ADC. Posting a block diagram of your design would help to understand what you are asking.
