mr_byte31
Full Member level 5
Hi All,
I am planning to build a ball mill due to its high price. A ball mill is a device to grinder any media.
There a lot of designs on internet , I like this one : https://youtu.be/kMgItVSmGDo
I have an issue to select a proper motor. I see some challenges here :
1-The jar will contain metal balls which will be a heavy load to rotate. (I think 1/3 HP at least would be needed)
2-The jar rotation should be constant (80 RPM).
3-It will run for long time <--- at least for 11 continuous days.
I have an old washing machine (Universal motor) but I think it will not be suitable since it will overheat due to the long running time and :
[Wiki] : "universal motors are best-suited for devices such as food mixers and power tools which are used only intermittently, and often have high starting-torque demands"
I thought about fan or water pump motor (induction motor), unfortunately the torque will not be enough to drive the full load. I will also need pulleys to reduce the speed.
I thought about DC motor since they have high torque and easy to control the speed. Unfortunately the price of the motor was high !
any suggestions ?
any suggestions ?
