sp
Full Member level 6
- Joined
- Jan 1, 2004
- Messages
- 395
- Helped
- 23
- Reputation
- 46
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Floating Garden
- Activity points
- 4,044
using an l297 with high amp motors
i c tht line i understand everything... and also wad i used to see y need so many C... now i start to understand... can i know who are you?... impressive...
for the home output, i connect it(home) to a 10kohm and the 10kohm(another node) to Vcc(5V)...and my controller read from the home output at the same time....
i use a multimeter to check the home output... all of the time it is 4.7-5V(high)... when i assert the reset_not(reset_not = 0 for L297) the home output is 1.2V(multimeter reading)... i assume tht when i assert the reset_not... the translator go back to 0101 state... so i think when it is 0101 state it turn on the transistor for the home, so the home is pull down to the gnd wth a transistor voltage drop(Vce) of 1.2V??.. i hope my concept is wrong too....
for the motor, i hav try many frequencies,,, but only 1000Hz works smoothly.. all other shakes a lot n very hot... when i used 1kHz, it very smooth n less hot(mayb)
100Hz i tried and shakes lot, first few try on reverse direction is working, after tht no respond D it continue turning same direction...
and one weird thing is tht the torque is higher when it spin faster... it is harder to stop it wth fingers than when it is running slow(easily stop)...
thank you Marcel Majoor... grateful..
my warmest regards,
sp
The reason for a smaller and a larger capacitor is that the smaller capacitor is used to filter out the higher frequencies and the larger for the lower frequencies
my warmest regards,
sp
