MOSFET Second order effects
MahmoudHassan
Full Member level 6
Full Member level 6
Channel length modulation , body effect , ssubthreshold region
iam asking about why these effects titled " Second order effects "?
what is the reason of this naming ?
They are deviations from the simple ("first order") MOS
device models, which originally used many assumptions
to make analysis tractable - such as long channel,
Vbs=0, and so on.
It's just English idiom.
You can approximate a set of points of the characteristic curve of a device by fitting a polynomial.
If the poly is of order one it is a linear approximation. It is called a first order approximation. If the poly is order two it is a second order approximation. And so on. The larger the order the better the approximation to the curve.
Simple device models do not take into account subtle effects so they approximations is not as good as it can be. Including more parameters into the model gives a better fit to the real curve of the device. So they are going to higher order approximations.
Thanks a lot for your reply :)
really appreciated
