mobile switch using microcontroller
sms controller circuit diagram
dear friends
has some one written code for any 8051 family ic to send n receive SMS .? and operate a relay...
tnaks in advance.
--Rony
parsing sms text in picbasic
Guys i need help here!
I'm working on Final year project for this year, my project is using a mobile phone just as a Modem to send and receive SMS control by the PC, and the PIC microcontroller is use to control the house system by respond to what the message is detected.
The PIC microcontroller with be connect to PC by through serial port.
At this moment i don;t know what type of phone should i use and what type of program should i wear on this project!
The mobile phone i have at this moment is Iphone 1G,Nokia E65,Sonic ericcson k700 and w850.
The program i search in web related to this topic is ActiveXpert sms/mms toolkit and SMS client.
Honestly i'm new in this topic i hope you guys can lead me forward!! Please
Re: sms switch
aanand_44 said:
If you want use only one relay for alarm purpose you can use pic16f688. in your project you have to use one GSM MoDEM for SMS receiving purpose. There are so many GSM modems are available in at various cost. then if you are deginner in PIC means go with CCS compiler. it will easy configure uart and port i/o. if you want circuit diagram 7 code,please ask me. I wil help you.
Anand
Hi.. i need a sample ckt to whcih can be controlled by sms. i have pic16f877a, benq m23 and im using MikroC as the code editor and proteus for the hardware.
My project is about controlling the system with SMS. I have a little knowledge in programming PIC.
Perhaps you can send me a sample program in which when i text "ON" the LED will light and "OFF", it will goes off. I just need a sample program which I can refer off. Hope you can help me.. Thanx
sms controlled switch
sms control circuit diagram
can anyone pls help me to get the circuit diagram of the sms controller using Nokia 3310..pls its urgent!!
hi.... I'm doing a project based on gsm..... I want send and receive sms using pic microcontroller 16F877A.. Mikroc is the software am using.. Pls send source code for this...
I tried to do the SMS Controller project.I used ATMEGA32 with Wavecom Supreme10 Modem & Codevision AVR Compiler. My problem is I can send AT command from MCU to PC Hyper Term & it works. I give reply typing on the hyperterminal which should be given by MODEM. Seperately Modem also works with Hyper term of PC. But MCU & Modem does not respond together. I dont know why.Can any body help?
Check the baud rate
check the stop bit and other settings.
Try swapping rx, tx lines (i.e. connect the tx line of micro to rx line of modem and vice versa)
Comeup with the results
Nandhu
Re: cell phone controlled switch
hi ananand ..
i too need to make this same project.i need to control more than 1 switch. but i dont know any thing abt getting this done...
Please refer the circuit. then Please let me know which type of modem your going to use. Then i will send u coding details.
Anand
---------- Post added at 22:24 ---------- Previous post was at 22:22 ----------
hi ananand ..
i too need to make this same project.i need to control more than 1 switch. but i dont know any thing abt getting this done....
so pls help me..i need to do this as my main project...
Anand
hi anand.
In your opinion which is the easiest one to program and the one that is cheaply available. is sim 300 modem good.
thanks
