stark21
Newbie level 2
Hello Dr Volker,
Thank you for your descriptive post. I am simulating RFCMIM capacitors in IHP PDK.
Do you recommend Momentum for simulating MIM capacitors at high frequencies? If yes, what should the meshing be if we want to accurately simulate the MIM caps at frequencies as high as 200 GHz? The design guide recommends meshing to be greater than 600cells/wavelength for accurate simulation and this setting obviously takes a lot of time. Are there any ways to work around this problem without compromising the accuracy?
Also, how accurate are the capacitor models for IHP SG13S?
Thanking you in advance.
