Min Channel BW for esprit
usamazahid1
Newbie level 1
"in your opinion, what would be the minimum per channel bandwidth that ESPRIT will need to give fairly good results? you need to give sir haroon, an upper and a lower estimate in terms of the number of bits and then use it to calculate the bandwidth. consider the case of eight antenna elements. you can suggest alternative opinions of approaching this question, if you like."
