- Joined
- Jan 22, 2008
- Messages
- 53,108
- Helped
- 14,792
- Reputation
- 29,871
- Reaction score
- 14,291
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 301,062
Nice that you visit your thread again.
As you surely noticed, I'm not the only one who can't follow your considerations. I don't see a purpose in repeating the arguments already said, nor trying to convince someone who doesn't hear.
In a short, you're saying that the unique and well-known text book theory about synchronizers is wrong. But the theory is pretty congruent with empirical results. I tend to the obvious assumption, that you simply didn't understand the theory.
Finally:
2. Binary data from an unrelated clock domain, that change on every clock cycle have simply a 'X' result. No synchronizer can help.
I'm discussing metastability from a practical viewpoint, because I'm using synchronizers every day. So I'm quite sure that the said text book statements are correct.FvM, you keep missing the point.
Finally:
1. You can't synchronize multibit data with a FF chain. The data can become inconsistent, because each bit can be only synchronized on it's own. It works under special conditions, e.g. gray encoded numbers that change incrementally, less than 1 count per clock cycle. So the discussion is clearly about single bit binary data.What happens if the incoming data is changing on every clock cycle?
