Measuring Input or Output Capacitance of a buffer
ashourism
Newbie level 6
Newbie level 6
Egypt
Hi
i am trying to measure the input and output capacitance of a buffer stage (for example) as i need to measure several other stages
i set up the following circuit
and i set the input voltage to 1.2 with AC Magnitude and Amplitude to 1.2 , also vdd is set to 1.2
then i calculated Zin = I/1.2 * f
however i get extremely variable outputs as in files and also no imaginary parts get in the output csv file from Cadence how is possible?
also how am i supposed to measure the output capacitance
So i made a mistake by dividing by 1.2 i divided by 1 and now i have a linear line with frequency but this is the total input Zin how i get the Input Capacitance (Imaginary)?
The change in impedance with frequency is the part caused by the capacitance. You can calculate the capacitance value from that.
so i used Cadence calculator to get the imaginary part of (I/V) then averaged it to get the slope this will be the capacitance?
What about the output i tried to the same technique but i got a non-linear curve
The output capacitance could vary slightly with signal due to the transistor junction capacitance change with bias voltage.
