Measurement and simulation in high frequency
isla4018
Newbie level 3
I have simulated S parameters of a PCB board from 0-10 GHz. The measurement data is agreeable with the simulation data up to 2 GHz. But after 2 GHz, measurement and simulation data are not that much close. I am assuming my simulation is correct. So can anyone please answer why the higher frequency affect the measurement? Or what may be the reason that simulation and measurement are not that much agreeable in high frequency?
Thanks
Simulation and measurement results are most of the times similar if you follow the simulation instructions correctly otherwise there should be definite mismatch of both results. In measurement the results also depends on the calibration of VNA, Connector characteristics, Material quality and thickness will change your results.
