kak111
MAX13256 : 36V H-Bridge Transformer Driver for Isolated Supplies
The MAX13256 H-bridge transformer driver provides a simple solution for making isolated power supplies up to 10W.
The device drives a transformer's primary coil with up to 300mA of current from a wide 8V to 36V DC supply.
The transformer's secondary-to-primary winding ratio defines the output voltage, allowing selection of virtually any isolated output voltage.
The device features adjustable current limiting, allowing indirect limiting of secondary-side load currents.
The current limit of the MAX13256 is set by an external resistor. An active-low FAULT output asserts when the device detects an
overtemperature or overcurrent condition. In addition, the device features a low-power mode to reduce the overall supply
current to 0.65mA (typ) when the driver is not in use.
The device features an internal oscillator for autonomous operation and an external clock source input to synchronize multiple
MAX13256 devices and precisely set the switching frequency. Internal circuitry guarantees a fixed 50% duty cycle to prevent
DC current flow through the transformer, regardless of which clock source is used.
