SidmasterSid
Newbie level 1
Re: Problem with Matlab 7
Changing the theme may work. The way I worked around the runtime error (after I did a clean install of Windows 7 and re-installed Matlab 7) was simple.
Heres what I did - hope it works
1) Control Panel ---> Look under system and security and select "find and fix problems".
2) Under the Programs heading select "run programs made for previous versions of windows".
3) At the Program Compatibility dialog box that opens just select next.
4) It will list programs ---> select Matlab 7.0, and at the next box select troubleshoot program. You can select then check the box that the program worked in earlier versions of windows and select next to continue.
5) At next box, select version of windows you previously ran Matlab on. At next box click "start the program". Allow it to open.
6) Matlab should then open and work without encountering the run-time error.
Windows will then say troubleshooting completed and then just save the settings.
Hope this works
Hope this works
