math formulation of phase difference between two linear polarization
yefj
Hello , I Have two linear polarizations wave propagates at z direction. one in 90 degree Y direction an the other in 180 degrees -X.
So there is a phase of 90 degrees between my polarization.
Why its not considered to be circular polarizar then?
Thanks.
If you can write your superposition like this:
then it can be written as:
so if you pick a fixed position as an observer like z=0, then you have:
And above expression shows that the direction of the electric field is rotating with time, therefore it is a circularly polarized plane wave.
Why do you say "so"? Phase shift between waves is an additional property and has nothing to do with oscillation plane. If both wave have additionally a phase difference, you get circular polarization, otherwise it's still linear, e.g. 135 degree if both waves wave equal magnitude.
