[SOLVED] Lpc2364 - Capture Timer 0 channel 1
Hi!
I tried it both ways replacing T0IR = 32 and 0x20..but its not getting the interrrupt i also removed the GPIO functionality part.
Yes i am clicking on the check boxes.
when i manually check the CR1 it goes in interrupt which is wrong!!!!!otherwise it remains in the while loop.
Similarly you can also see the breakpoint in the first image at line 46.
I have attached the images-> simulation time.
Don't use the FIOSET / FIOCLR register checkbox, these can't change the port because the pin P1.27 is not GPIO anymore.
Use the "Pins" checkbox , it is the last line in the dialog, uncheck and check the pin from there.
Alex
Hi!!
Just check if this is correct ?
should i tick the encircled pin high - low if it is....
Then i am getting the interrupt ....Please reply and see the attached image.
Thanks and Regards
hrishikesh.
Thanks alot Alex....will meet with new Issue...be ready my friend.
Hrishikesh
---------- Post added at 16:56 ---------- Previous post was at 16:54 ----------
Hrishikesh:lol:
