[SOLVED] LPC2138 simulation in proteus not working
How to solve errors in this message??? Or I can ignore this messages (in red)???
ISIS Release 7.10.00 (Build 12325) (C) Labcenter Electronics 1990- 2011.
Source code build completed OK.
Compiling design 'C:\Temp\MCU\ARM\LPC2131\Teste\Teste.DSN'.
Netlist compilation completed OK.
Pin 'RTXC1' is not modelled.
Pin 'RTXC2' is not modelled.
Pin 'XTAL2' is not modelled.
Pin 'XTAL1' is not modelled.
Netlist linking completed OK.
Partition analysis completed OK.
Simulating partition [0CB581F8]
PROSPICE 7.10.00 (Build 11592) (C) Labcenter Electronics 1993-2011.
Loaded netlist 'C:\Users\CLODOA~1\AppData\Local\Temp\LISA2889.SDF' for design 'C:\Temp\MCU\ARM\LPC2131\Teste\Teste.DSN'
[ELF] Loading ARM ELF file 'Teste.AXF'.
Memory configuration: 32KB ROM, 8KB RAM
Thanks.
  • Teste.rar
Thee is no need to use the XTAL pins for simulation, just set the crystal frequency in the clock frequency property of the mcu (double click on the mcu to open the dialog)
Thank you all for your valuable time and comments. Finally I got this working. To my surprise the issue was with Proteus software. I upgraded 7.4 to 7.10 and things are working.
