goldsmith
Advanced Member level 6
- Joined
- Dec 14, 2010
- Messages
- 3,981
- Helped
- 741
- Reputation
- 1,486
- Reaction score
- 726
- Trophy points
- 1,413
- Location
- Tehran - IRAN
- Activity points
- 24,546
Hi EshalBy the way, how much output power needed to transmit a signal over the range of 50m?
I know it , but the problem is that you don't have an standard antenna ( with standard distance and with standard connectors and standard cables ) in your university to test ! so , prediction is a bit hard with these problems .BTW: in university, there are not tall buildings, just 2 or 3 story buildings, not more tall than these buildings.
Perhaps he can use a simple radio receiver and walk until 30 meter ? ha ha ! a funny event ! :grin:Are you getting my point? What I mean to say?
Yes , it is pretty simple ! just a current driver should be added and supply voltage should be increased , as an example , it can be ok too ( but it is around 1 W ) see below , please :OK then you are going to help me in increasing output power for my project upto 2 or higher watts bro. Are you?
Of course I can, but according to the requirement of project, will it be under the category of low level or it would be call high level AM transmitter?You can easily increase it's power up to some hundred watts .
Yes , i told you some watts , is low , too !But one thing just come in my mind now, If we increase power, will this transmitter still categorized as low level AM Transmitter, as our teacher said to design, huh?
After some hundred watts no !Of course I can, but according to the requirement of project, will it be under the category of low level or it would be call high level AM transmitter?
But it is bot important to have RF instruments as start ! when i have started RF , design , i didn't have many of the required instruments , and during each project i bought them , one by one !I can't provide numerical values since i do not have special rf instruments
It seems good idea !I would suggest to use the 3.5 MHz frequency
Ha ha ! well ! a Gentleman ! ;-)yes, that's me in the middle
You mean if RF frequency is 3.5MHz then, range could be ~50m. Is that are you trying to say zsolt1?I would suggest to use the 3.5 MHz frequency
