Looking for schematic for ICD2
circuit icd2
I'm not sure what really happens on boot up. normaly the CY7C64613 loads its code from USB. but it can also retrieive some configuration data from the EEPROM. CY7C64613 also offers to boot completely from EEPROM. at the moment i have no idea what's going on on the ICD2.
I'm working on it.
j
icd2 u6
The firmware for the CY7C64613 in the ICD2 is downloaded on the USB interface. If you look in the ICD2_USB drivers directory under MPLAB, there are two ".inf" files: one loads a driver for the "raw" CY7C64613 and the other loads a driver for the configured CY7C64613.
The EEPROM in the ICD2 has to contain the correct enumeration information (vendor ID and product ID) so that the Windows driver will recognise it and download the firmware. The file "icd2.mp3" looks like it contains the correct data (the numbers match the ".inf" file settings), but I haven't checked this.
I was also hoping to build a USB ICD2, but can't find anywhere in the UK to get the 52-pin CY7C64613 (the 80-pin version is available from RS).
Hope this helps. :)
icd2 pic schematic
yo, thanx
other question:
someone knows what value to use for the USB power inductivity. on the pictures of ICD2 found in the forum icd2.de.vu denoted as L2 and L5. the inductivities are used to limit the inrush current.
j
pic-icd2 schematics
Did somybody build ICD2 with RS232 successfully? I want to build one by using information in this post. RS232 is enough for using.
circuit of icd2
hi all
yet another schematic.
finally i finished to enter the schematic with USB interface. feel free to check for errors. my design is completely SMD. I will publish the PCB in *.pdf format as soon as I finish the layout.
j
(unfortunately I can't share the *.sch and *.brd files, you know why :wink: )
icd2 + schematic
Hi taylor2000
For the ICD2 with RS232 interface i've already post schematic and any informations to build it on the forum.
CD:)
ts 34063 schematic
Hi jenda
I've look for your schematic, i thnik it was a problem with the buffers 74HC125.
You must put two 74HC125 in parallel for each entry. I've realized it with only one on each entry and it doesn't work correctly.
Look at my schematic on the board, or on www.mcu.cz, you will seen how the buffers are plugged
CD:)
schematic pic icd2
Hi Jenda,
Good work!
However, you seem to have missed out the 1M resistor in parallel with Y2. Also according to the EZ-USB data sheet, R34 and R35 shoudl be 1K not 10K.
icd2 scheme
hi zaphod42 and crazyduck
R34 and R35 are definitely 1k and the 1M resistor in parallel to Y2 is missing.
has someone an explanation why I should use two 74HC125 in parallel for the input buffers? I think this buffers are powerful enough to drive the load.
thanks a lot for your check!
j
pic icd2 wiring
Hi Jenda,
Don't know why, but if you don't pull two buffers in // it doesn't work well.
CD:)
pic18f458 icd2 schematic
Hi Jenda & CrazyDuck,
The original ICD2 uses a 74HCT device for the input buffers. Maybe this explains why it only needs one gate but CrazyDuck needs two. My prototype using DIL ICs works fine with a 74HCT126 with inverters on the enable line (as per real ICD2).
Zaphod
icd2 pcb
Message to crazyduck.
Where can I find the PDF-File with the schematic.
Thanks
Maniac
icd2 circuit and pcb
Hi Maniac
Please try to use search before posting. Either search for posts made by crazyduck or search for ICD2 schematic.
Cl
pic icd2 emulator schematic and pcb
hi
I found some other bugs concearning the buffers. the input-buffers should accept TTL levels as mentioned above. therefore a 74HCT125 has to be used. the output buffers are standard CMOS 74HC126 and are powered from the target. as a consequence U9C has to be exchanged in order to get the right supply. so I used the third gate of the 74HC126 and changed U15 from NAND to AND like it is done by microchip (see pics foun on EDAboard).
I will post an updated version later when all bugs are found.
j
icd2 schematic and firmware
bufers on 74HC125 and 74HC126 in my design from www.mcu.cz is parallel only for corecting level on unused gates and simplify DPS :) :) :) realy nice joke, no :lol: :p :lol: :p :lol:
schema icd2 microchip
Output bufer (74HC126) is powered from target due to corect level for target power in range 2-6V. Input buffer is power from ICD2 and transform input levet (2-6V) to corect for PIC in ICD2
74ahc126
RB3_T (pin 6 on target connector) is unused in real work, will be used in future version of MPlab. Buffer is controled via AND gate, not NAND !!!!!!
mplab-icd circuit schematic
Hi
The /ENABLE input of the thirt output buffer is also inverted. That is the reason why I used the NAND. What I messed up is the supply of the buffers. I changed it and use now a NAND and a noninverting ENABLE. All output Buffers a powered by the target and the input buffers are powered form ICD2 and are TTL level. As mentioned I will post the final version later.
say tuned, j
pic16f88 icd2 schematic
To order the demand from sam_manchali,
I'll post the PCB of RS232 ICD2 in gerber format.
CD:)
icd2 18f4550
does this ICD support the same devices like the one from Microchip or which differences are there ?
Thanks
Mr Huge
